Old 04-17-2007, 04:08 PM   #2
IHateHacks
IHateHacks's Avatar
Sounds like you have found a pretty good mechanic. In a wheelchair? Now that takes some determination.
The coolant and vacuum lines I am talking about are underneath the intake manifold, can't get to them unless the whole intake manifold is off. And also the 2, 90 degree coolant lines at the rear of the engine and under the water outlet housing which you can't replace unless the head is taken off. There are probably a dozen hoses that will be so dried and stiff that they will crack when trying to take them off. And at $20-$30 a pop they add up quick, about $250 just in little coolant and vacuum lines.
This mechanic probably knows this already but make sure he replaces the fuel injector insulators and O-rings. The insulators are the rubber seals that seal the injector to the head. It's little parts like this that add up quick. I'm not just pulling a number out of my ass when I say $600 in parts. I have the receipts to prove it.
