Old 04-16-2007, 04:46 AM   #1
mrnickleye
mrnickleye's Avatar
I believe you are saying that your plugs were coated with oil...wet oil !?
Yes? Then the hole the plug sits down in is full of oil. This gets in from leaking valve cover gaskets.
Chamge them. and the center one over the plugs, and that will fix the problem.
Read the Got oil on top of your spark plugs?? thread in the
MKIII (1986.5-1992) section.
