Old 04-14-2007, 07:15 PM   #1
supramacist
supramacist's Avatar
Tricky Q you have here. In all honesty these cars pretty much come stock with a bhg. I think retorquing the bolts may prolong it. But you have no idea how the car has been driven. I read somewhere that most stock hg's blow between 60k and 80k miles. But if your auto hasn't been driven it's a hard call to make.
If it's not blown already it will blow sooner or later. I would invest the money from all of the testing into a new MHG and retorque it and see how it acts.
There are tale tell signs that the hg is about to go out. You can check the oil fill cap. If there is a white milky residue then your about to have problems. Check the radiator overflow. Make sure there has never been oil in it. Wich I think happens due to blow by.
I have a 91 na and I bought the HKS stopper MHG 2.mm. Right at $300.00
And countless other parts. If I could go back and do it all over again. I would park the car pull the engine tear it down and rebuild it totally. In a perfect world where money grows on trees, right.
