Thread: new motor
Old 04-06-2007, 01:59 AM   #1
west_side_supra
west_side_supra's Avatar
245892 (86-87) Toyota Supra 86-92 A1 Rear Traction Arms - Pair $170.00 $170.00
19282 Toyota Supra 86-92 AEM Tru-Time Adjustable Cam Gears - 7MGTE - Polished (3 Bolt Design) $169.98 $169.98
47787 (87-88) Toyota Supra 86-92 AEM EMS Engine Management Stand Alone - Turbo, M/T Only $1,758.07 $1,758.07
312372 Universal Aeromotive High Flow Fuel Rails $39.00 $39.00
131593 Universal Apexi Power Replacement Air Filters - UNIVERSAL FILTER AND 75MM FLANGE $82.67 $82.67
8021 Toyota Supra 86-92 ARP Head Studs - 7MGTE (includes nuts) $121.08 $121.08
229017 Toyota Supra 86-92 Cooleeze Intercooler Piping Kits - with Spearco IC and HKS BOV $498.75 $498.75
115127 Toyota Supra 86-92 Cusco ALC OS Strut Tower Bars - Front (Special Order) $181.40 $181.40
136952 Toyota Supra 86-92 Endless 4 Piston Slotted Rotors Big Brake Kits - (86.5-92) 1-pc 302x22mm $3,060.00 $3,060.00
56889 Toyota Supra 86-92 Greddy Extreme Timing Belts - (turbo) 7M-GTE $122.43 $122.43
3738 Toyota Supra 86-92 HKS Downpipes - 75mm Pipe Dia. $185.06 $185.06
3620 Toyota Supra 86-92 HKS Super Drager Exhaust Systems - Turbo (85mm, 120mm tip) $602.44 $602.44
6291 Universal HKS Adjustable Fuel Pressure Regulators - 2.0 5.0 kg/cm2, 28 71 PSI $171.60 $171.60
992 Universal HKS In Tank Fuel Pumps - 71gph@45psi $554.40 $554.40
4714 Toyota Supra 86-92 HKS Metal Head Gaskets - Bead (2.0mm thick, 86mm bore) $239.11 $239.11
1123 Universal HKS Racing Type S S Wastegates - 1.6 kg/cm2 (brown) $611.60 $611.60
48869 Toyota Supra 86-92 Hose Techniques Hose Kits - Turbo - Super Red $68.00 $68.00
136492 Toyota Supra 86-92 LIPP MK3 Bolt-on Turbo Kits - Stage 5, TO4E 68 (700hp) with lines and big shaft $1,635.00 $1,635.00
84869 Toyota Supra 86-92 Powerhouse 7MGTE Exhaust Manifolds $699.00 $699.00
110689 Universal RC Engineering Saturated High Resistance Fuel Injectors - 650cc $94.94 $94.94
134261 Toyota Supra 86-92 RK Bushings - Full Kit $650.00 $650.00
9636 Toyota Supra 86-92 Suspension Techniques Sway Bars - Set $264.85 $264.85
100444 Toyota Supra 86-92 Tein Super Street Type SS Coilovers - (Drop 1.8" Front, 1.3" Rear) $950.00 $950.00
46387 Universal Vibrant Universal Catalytic Converters - 3" Inlet/Outlet ID, Oval Body, 16" length $79.74 $79.74
184118 Toyota Supra 86-92 Yonaka Motorsports Complete Engine Gasket Sets - 7MGTE $147.15 $147.15
1% Online Discount (for items not on Clearance) $-131.56
No Sales Tax $0.00
Estimated Shipping & Handling within Continental US $321.38
Total $13,346.09
i think that was about all
all parts and numbers are from http://www.horsepowerfreaks.com
i chose this because i live in washington and they are in portland so cheap shipping and no sales tax
oh and one last thing, im having troubles finding out how to change the BGH with the motor already out of the car. it gets confusing with the other ones that tell you how to do it while in the car dissconnect this wire and that. i dont have anything on there its just the block, only things missing are the TB,3000,IC&pipes,turbo,and fan.
7MGTE - 500hp never dyno'd
fidenza cam gears
