Old 04-05-2007, 11:54 PM   #1
godmachine
godmachine is on a distinguished road
Default same problem!
Originally Posted by blitzmkiii
the speedo dont work, the gas gauge will only go to half a tank, ......, temp always on hot, oil pressure is messed up, but the tach works perfect
i just bought an 87 turbo with aftermarket gauges, and it has almost exactly the same problem!! i'll try these suggestions to fix it, but i wanted to ask, did you ever end up solving this? if so, did you pinpoint the exact problem?
thanks!
godmachine is offline   Reply With Quote
