Thread: codes 22 24 31
Old 04-04-2007, 12:35 AM   #3
JunkerMK3gte
JunkerMK3gte is on a distinguished road
yes, it is the seals/bearings. pull it now and replace/rebuild it before you fry the turbo all together. Garrett turbos has the best of anything you need to do. it costs a bit more, but you wont have to worry about it again.
Originally Posted by Reeves
I have some radial shaft play on my turbo. I believe the oil seals are blown because i get a good amount of blue smoke. It only smokes after I push it then put the clutch in and let it idle, blue smoke will pour out for a bit. There is a lot of oil in the intercooler pipes so im thinking it's pushing oil through into the engine. also no smoke on startup..
What do you guys think?
JunkerMK3gte is offline   Reply With Quote
