Thread: codes 22 24 31
Old 03-29-2007, 02:10 AM   #2
IHateHacks
IHateHacks's Avatar
Unless you are blowing clouds of blue smoke under load or WOT, your turbo is fine.
The only thing you can check with the turbo bolted to the engine is axial shaft play. You can check radial shaft play also, but ANY axial shaft play is very bad.
Axial=in and out
Radial= side to side
