Old 03-26-2007, 08:01 PM   #1
f00g00
sounds like the center bearing that connects the two small driveshafts together. If you change it yourself be careful to mark the way they came off so you don't get the driveshafts out of alignment or you will get some serious vibration problems at around 60 mph. The driveshafts and center bearing are balanced at the factory.
