Old 03-22-2007, 01:15 AM   #3
IHateHacks
IHateHacks's Avatar
I just took it for granted that your timing was set properly.
I highly recommend you set base ignition timing. You need a timing light and must jumper terminals T and E1 with the engine at full operating temp. Base ignition timing should be set to 10 degrees BTDC.
