Old 03-16-2007, 07:13 AM   #16
WhisPer
WhisPer is on a distinguished road
I might run low boost on 91 so somewhere around 13-14 psi right? and I will run highboost on 100 octane
wouldn't do nitrous just because it's cheap...because if you do nitrous properly, it's actually not that cheap. When you price in the cost of a wet kit (not dry), automatic electronic rpm limits, purge kit, separate test switches for your fuel solenoids, in-dash electronic nitrous pressure gauge, bottle blanket, plus proper installation, testing & tuning, it isn't what I'd call a cheap proposition. Again, I do recommend it in general, but only if you do it right
Well I would just buy a wet kit thats it, you dont need a purge kit you can just purge the bottle after use right? and if you know what your doing you dont need the rpm lights.
WhisPer is offline   Reply With Quote
