Old 03-14-2007, 11:13 PM   #10
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by WhisPer
...Yes I agree suspension is very imprtant. Do you think some adj. shocks with a lowering spring would be sufficient or just a full adj. coilover system? I also might get a front and rear sway bar and a few strut bars..
For the applications you're describing, the oem mkiv tt suspension would do just fine. If you simply must lower the car for looks, sure a full set of coilovers and sway bars would be nice, but until you're extremely experienced driving your Supra, you probably won't be able to take advantage of those suspension components.
...Also I was wondering how the clutch is on a mkiv does it hold power well?...
No, the oem clutch holds only about 375rwhp or so, reliably, depending on how hard you drive it...fwiw mine failed about 5K miles after I went bpu, and I'd put over 40k miles on it with oem boost.
Life begins at 30psi.
