Thread: Gas + oil
Old 03-14-2007, 01:01 AM   #2
mrnickleye
mrnickleye's Avatar
Code 52 is not cat related. Its generally the knock sensor, or the wiring to it.
The gassy oil is either: you haven't changed the oil and filter in a very long time, or the PCV system is plugged up, or you are running way too rich (and the extra fuel is slipping by the piston rings). Or ALL of the above.
No matter which, you need to fix it, as your cylinder walls won't last long with this problem.
