Old 03-13-2007, 11:10 AM   #3
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Malachiman
1995 Turbo. I got the speedo working just by tapping the window but the Diff light is still on.
Is your Supra equipped with a differential cooler? If so, it's very likely the problem is associated with that subsystem. It's possible, for example, that there is a problem with the electrical connections to the motor that pumps your diff fluid through to the cooler. Also, when was the last time that you changed your diff fluid ...and how many miles on your Supra?
Life begins at 30psi.
