Old 03-10-2007, 02:56 AM   #1
mrnickleye
mrnickleye's Avatar
Yes....but its not the bearings in the alt. its either the brushes, or the regulator. Get a reman unit from a GOOD parts store.
And save yourself 2x the work...NOT from the autozone !!!
Kragens Autoparts:
Autolite Import 14611 Remanufactured; With Manual Transmission
Limited Lifetime Warranty*
Immediate availability
List$199.48 Wholesale$92.76
All Autolite Pro-Tech?™ Alternators are 100% tested to meet or exceed Original Equipment specifications for voltage and amperage.
Pulleys and Fans - 100% Remanufactured - Inspected for alignment and groove clearance, painted or plated, and torqued for lasting performance
Voltage Regulators - 100% New or tested for maximum operating voltage
Insulators - 100% Original Equipment Quality - High temp for long lasting reliability
Rotors and Stators - 100% Remanufactured - Electronically tested for performance and maximum output
Brushes - 100% New brushes and springs to ensure long life
Bearings - 100% New or replaced with quality remanufactured bearings, packed with high temperature grease
Diodes and Rectifiers - 100% New or remanufactured
Limited Lifetime*
