Old 03-06-2007, 09:05 PM   #2
IHateHacks
IHateHacks's Avatar
"Do you have any idea what could be causing the ticking?"
Your valve clearances need to be adjusted. There are shims inbetween the cam lobes and valve lifters which need to be at a specific size. It's not a hard job, just very time consuming and there is alot of math involved. Plus you need special tools to remove and install the shims. Not a job for an amateur.
