Old 03-06-2007, 04:56 PM   #1
dcrusupra
dcrusupra's Avatar
Whens the last time the car had an oil change? Drain the oil and see if it's milky or if it's bubbly coming out. If it's not, then do a compression test. Anything under 120 then you'll need a rebuild regardless of a BHG or not. If it is a BHG get a stock toyota gasket. Unless your going for high boost, in which you'll need to take the whole engine out of the car, send the block and head to a machine shop so they can machine them and lap the block.
If it's not a BHG and your compression is fine, then you may be losing coolant from a leaking hose, the hose at the back of the engine looooves to leak and is a biotch to get to. And if the needle is fluctuating, check the connection on the temp housing. It may be loose.
New Rebuild
My CarDomain
