Thread: 97 MKIV problem
Old 02-27-2007, 12:22 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by excesss
...I recently purchased a 1997 N/A automatic supra. I put about 100 miles on it and the check engine light came on so I got a buddy to hook up his module to see what the code was. I dont remember the exact wording but it was something to do with insufficient exhaust flow (code PO401). He said it could be many things, possibly an EGR valve. Anyone have a problem like this or know what the problem is?
Your buddy is right...it could be many things, but I agree that one of the first places to check is the egr valve itself. After 100K+ miles, the valve can get carboned up, which could restrict egr flow. You could try disassembling it and cleaning it...or replacing it with a new egr valve from 'yota.
P.S. I'm assuming this is the only code showing up in your ecu...and that your Supra is otherwise in perfect running order.
Life begins at 30psi.
