Thread: ball joints
Old 02-26-2007, 02:54 AM   #1
supradaddy0803
supradaddy0803's Avatar
It is actually easy you basically look on the back of the spindle and you will see a castlated nut on the bottom and the top the one on the bottom is the one you are looking for. Pull the cotter pin out and loosen the nut heres the fun part pop the stud out of the spindle and remove the three bolts from the lower A arm and the whole assembly slides out. I looked all over when I got ready to do mine they dont even actually sell ball joint to be pressed out the assembly you buy is the one you need.
