Old 02-24-2007, 04:06 AM   #7
west_side_supra
west_side_supra's Avatar
ok well ive put more gas in, and it was running fine for about 3 days then i pushed it hard and long and the check engine light came back on, did that slow down thing almost as if the clutch was slipping. but thats definatly not the case. so i went around asking my local shops and car peoples what they think it may be this is what i have gotten so far
1.Injectors
2.Fuel filter
3.Accordian hose (inlet pipe for turbo that ugly rubber thingy)
4.timing
5.CAT
6.oxegen sensor <that didnt make sense to me because if it was that the case then the light would be on all the time
7MGTE - 500hp never dyno'd
fidenza cam gears
