Old 02-21-2007, 03:08 AM   #3
supradaddy0803
supradaddy0803's Avatar
My old 86.5 did the same thing and what it was the negetive battery terminal was cracked and loose and when you turned the key on at first the lights and everything worked then go for a start and everything died and went completely off. It might look fine if it is the factory one just grab on the insulated part and shake if it is loose then tighten or replace.
