Old 02-14-2007, 10:12 AM   #1
73corona
73corona is on a distinguished road
Talking
hey mate iv got a 3rd gen 1gg & i am just fitting a t3/t4 when it turns up.just have to make a simple y pipe.should be able to run same boost as before 11psi std & 14psi on high may have a bit of lag but lag is just a clutch kick away.you will just have to make sure you dont run lean.sugest dyno run after you fit turbo to find out how much boost to run without running lean.dont be scared.
73corona is offline   Reply With Quote
