Old 02-13-2007, 07:28 PM   #3
IHateHacks
IHateHacks's Avatar
"my turbo and my turbo manifold is glowing red hot"
The exhaust manifold is most likely warped by now. Warpage limits for turbo exhaust manifolds are .0197 in.
Did you set BASE ignition timing? This is done by disabling the electronic advance. Base ignition timing for a turbo 87 should be 10 degrees before top dead center (BTDC).
