Old 02-11-2007, 11:53 PM   #1
Burn N' Up
Burn N' Up's Avatar
Bump! Help!?
89Turbo 5 speed:Eibach lowered,Tokico Illumina II TEMS,All Poly Bushings,3" Elbow/DP/Cat,HKS Sport Turbo Exhaust,K&N FPIK w/ AEM Dryflow,Cooleeze ceramic coated Turbo inlet Pipe and 2.5" hard IC Pipes,Custom 2.5" fitting Spearco IC,HKS SSQV BOV,Greddy 1.5mm MHG and timing belt,Magnecore Comp Wires,NGK IR Low-temp Plugs,ARP studs,Dual Flex-a-lite fans w/ thermo switch,Fluidyne Rad,PCV VTA,Stage 3 F1 Racing clutch,Stainless braided clutch line and brake lines,Drilled & slotted rotors,EBC pads.
