Thread: Igniter Plug
Old 02-10-2007, 02:55 PM   #1
IHateHacks
IHateHacks's Avatar
"no where on the car can i find the plugs to plug underneath coils. Is it supposed to be on the coil pack or harness? can i buy it seperate?"
Sounds like you are missing the harness for the coil packs? It is only on a GTE engine harness, and it looks like this- 3 black 2 terminal connectors on one end that plug into the coil packs and 1 green colored connector on the end that plugs into the main engine harness. The green one looks just like the one for the cam position sensor. I'm sure you can get just that part of the harness from the dealer, but that won't help you if you have a GE engine harness.
The igniter is that silver box behind the diagnostic connector behind the battery. Has a 6 terminal connector and a 4 terminal connector coming out of it if its for a GTE.
