Old 02-09-2007, 03:04 AM   #2
IHateHacks
IHateHacks's Avatar
7MGTE were turbo only
7MGE were non-turbo only
Thats what the T means, turbo. Someone swiped it before you bought it.
So if I understand this correctly, you have a 7M GTE engine with a 7M GE exhaust manifold bolted on, correct? I just have one question, are the turbo oil line bosses blocked off? (where the turbo oil line would bolt to the block, one is a 2 stud/nut flange, one is a 17mm union bolt)
I'm guessing you are using the injectors that came with your GTE?
I'm also guessing you are using your GE ECU?
What did you use from your blown motor to make the GTE run?
