Old 02-08-2007, 03:30 PM   #1
redmaro
I've changed the coolant temp sensor and it only dropped the Rpms to around 1000. Now I'm going to calibrate my TPS sensor, I have aleady taken out the whole throttle body. But I see that the throttle stop (The little screw bit) isnt in contact with the throttle lever (The springy bit that gets pulled when you press the accelerator). Should I move the stop screw untill it comes in contact with the throttle lever?
MK3, Auto, Turbo.
