Old 02-08-2007, 12:43 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by kidsusukigsxr
...can anyone tell me about the emissions control system diagnotic code 25 air-fuel raio rich malfunction. I don't know which sensor i need to change...
  1. Diagnostic code 25 is "Air-Fuel Ratio Lean Malfunction" (i.e. not "rich" - that'd be code #26)
  2. Possible areas of concern are as follows (listed roughly in decreasing order of likelihood):
    • Main oxygen sensor (a likely cause)
    • Air/vacuum/boost leak (also a strong possibility)
    • Water temp sensor (sensor corroded, due to infrequent coolant flushes)
    • Ignition system (old spark plugs (copper?))
    • Air flow meter (dirty/oily (from k&n oil?))
    • Fuel line pressure (eg. bad fuel pump)
    • Injector (dirty)
    • Open or short in main oxygen sensor circuit
    • Open or short in Injection circuit
    • ECU
Of course, other members of the forum please feel free to correct, re-order, or add to this list.
kidsusukigsxr, please answer the following questions:
  • What year is your Supra? ...and is it turbo or n/a?
  • What modifications were done to it?
Life begins at 30psi.
