Thread: Alternator?
Old 02-07-2007, 02:04 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by bpalmer21
Well it has been sitting discharged for 2+ months now then. I talked to optima and they will replace the battery under warranty so when i get the new one ill just leave it till I can start driving it again. Yes?...
Honestly, I'd recommend putting a charger on it when you first get it, just to be sure its charge is completely 'topped off'. After that, yep just leave it disconnected until you start driving.
There's an 'old wives' tale about not letting it sit directly on a concrete floor, but that myth has been 'debunked' afaik.
...Any easier ways to find what is drawing power when the car is off?
No...at least not that I'm aware of. The procedure that Mr. Nickleye described is about as straight-forward as can be.
Generally though, an unmodified/factory/oem vehicle doesn't draw very much current at all when the vehicle is sitting. Many abnormally high current draw situations associated with prematurely dead batterys are related to mods/upgrades. I'd suggest you start the fuse-pulling exercise with any circuits associated with any aftermarket electronics modifications on your Supra, such as boost controller, fuel controller, gauges, turbo timer, security system, stereo system, etc...
Life begins at 30psi.
