Old 02-07-2007, 01:57 AM   #1
rnoswal
rnoswal's Avatar
If it ran fine before then it should after the repair. The only thing I can think of is that you might have the cam timing off. You can have either or both off and not have any mechanical damage, but it won't run very good. You might want to check your cold start injector switch or one of the other cold temp switches. If the car thinks it is always cold it will continue to run rich.
Let us know
Russ
