Old 02-06-2007, 01:10 AM   #4
sd88supra
sd88supra is on a distinguished road
Originally Posted by mrnickleye
Carb spray down the holes will work. Or brake cleaner spray is less strong, safer.
The oil down on the spark plugs/boots can cause a misfire. You need to fix the leak. Usually the V/C gaskets, #1 & #2. Not the center one. Not a difficult job at all.
before I teared into the head, I looked for the V/C gaskets in the TSRM and Haynes manual. However, the gaskets are just labeled "gasket" and I'm not sure which ones you are referring to as #1, #2 and center. What do I need to remove to get to the gaskets youre referring to?
Also, could the oil down the spark plugs be a cause of worn piston rings? if so, would I need a valve job or a rebuild?
sd88supra is offline   Reply With Quote
