Old 02-05-2007, 03:32 AM   #2
SideWinderGX
SideWinderGX is on a distinguished road
Originally Posted by Murd
You don't need a metal head gasket if you're going to be running stock boost or slightly over stock. Just make sure it's torqued to 70-80ft/lbs. If you're not getting the block lapped you're probably better off NOT getting a metal head gasket as well... Both surfaces need to be extremely smooth to use a metal one. Get a stock head gasket kit from toyota, it should have all the parts you need in it, grommets and all. I'd suggest still taking the head to a machine shop however.
what id love to do with the car is leave the turbo as it is, then slowly phase in some other parts....which i havent decided yet :-P or maybe i wont, ill just have fun with it and see how long i can keep her alive. either way, she isnt going above 300 HP unless i hit the lotto.
i just wanna fix this problem so i wont have to worry when im driving the supra...much like im worrying now haha. and if i get that stock head gasket kit from Toyota, that wont include ARP studs\bolts, correct?
whats the difference between studs and bolts, anyways?
thanks for all the info
SideWinderGX is offline   Reply With Quote
