Old 02-05-2007, 03:13 AM   #2
IHateHacks
IHateHacks's Avatar
"Total part will probably run you around 350$"
Incorrect. That will cover the machine work on the head, the head gasket itself and head bolts. And yes, heads should always be sent to a machine shop regardless of what you think. You then need a turbo gasket set which you can only get at the dealer and is $95. You need intake manifold and intake chamber gaskets, fuel injector insulators, grommets and O-rings, copper sealing washers for the fuel rail, fuel line, and turbo oil feed, exhaust manifold gasket, EGR cooler and EGR valve gaskets, etc..... If you look at my BHG post I have a detailed list of all the parts that are needed to repair a head gasket and the prices. The price is more like $700 and thats with a stock head gasket. Metal head gaskets are easily $200 themselves. I paid $99+ shipping for ARP head bolts. Be prepared for extensive labor if you do it yourself, 20 year old gaskets don't just peel off. You better have the tools or a hook up for the tools or that bill will easily add up to $500 itself.
