Old 02-04-2007, 09:15 PM   #1
Kuban
Kuban is on a distinguished road
If you are going to do the replacement right away it wouldnt be a bad idea either way. No matter how many miles the engine has on it. If its a stock hg, and the head bolts were torqed to fsm standards it could blow under randomness situations. BUT if the head bolts were torqed a little above fsm standards, say around 80ftlbs than i wouldnt worry about it if your running stock boost with no mods. But if you plan on changing it out heres what i recommend.
ARP Head studs
105.00$
https://935motorsports.com/catalog/p...oducts_id=1022
Cometic 2mm Steel Multi-Layer
169.00$
https://935motorsports.com/catalog/p...roducts_id=767
That would be a good setup. Then of coarse new gaskets for the things you end up doing in the process (Intake, exhaust, turbo-manifold etc.).
Total part will probably run you around 350$ or so. IF your doing the job yourself. My good friend whos a mechanic said the standard time for the 7m by shop standards is rated at about 12 hours labor. Depending on the shops labor charges, could be as much as 1000$ in labor to as little as 700$.
All in all its not costing you more than 1500$ tops to get the headgasket redone with a hg that will sustain 30psi all day long.
Now say the hg is already blown. Then were talking about pulling the engine and sending the block and head out to a machine shop and get then resurfaced. Prices on that are grey area. Just hope its not already blown basically.
Good Luck!
*EDIT* The 7m is a I-6, not a v6 as alot of people commonly confuse it, thus there only being (1) headgasket.
Kuban is offline   Reply With Quote
