Old 02-01-2007, 07:33 PM   #3
kidsusukigsxr
kidsusukigsxr is on a distinguished road
Default great!!! ECU Question
Hey thank you for answering. That helps out alot. I was only thinking of downgrading because I can't find the parts or there to expensive. I'm just trying to get the car running. I'll stick with the cam set up and go from there.
1. Could you tell me if there is a way to determine if my ECU is working?
2. The spark plug coil system (if thats what its called). In order for it to work correctly all 6 plugs should be connected and should there be any other wire connected to it , going to the alternator. I'm learning and not a mechanic at all. I bought this car from a guy who was working on it and i don't know where he left off. He is helpful.
kidsusukigsxr is offline   Reply With Quote
