Old 01-30-2007, 05:52 AM   #1
Murd
Originally Posted by kwnate
Are you planning on turbocharging your NA? If not your going to lose alot of HP using the gte pistons.
Yep yep, you'll drop your compression, N/A's work more on compression than displacement. Well thats a lie in a way, but you need compression on a N/A motor. Even if you up the displacement, you have to find a way to up the compression, such as thinner HG, shaved head, domed pistons.
