Thread: gasket help
Old 01-18-2007, 06:46 AM   #1
hangsupra
Originally Posted by mrnickleye
dealer only.
http://www.cygnusx1.net/Supra/Librar...ion=EM&Page=32
you could do as said above and use engine oil drain plug aluminum gasket washers (any parts store). and not use the #3 gasket.
Be sure to replace the #1 & #2 valve cover gaskets to keep oil out of the spark plug holes. (any parts store will have)
Carquest part # GSK VS50049 $26 min to $49max
thank you for the url....
i got the books here too hehe... thanx anyway...
well... can i do like you said... use some aluminum washers and some jb weld stuff. and put it back together and dont use the #3 gasket... (if i do this, i wonder how long it will last)
i already got myself a napa valve cover gasket witht hose round seals too... i already got that..
about the #2 gasket... i dont see any oil leak and stink on the timing belt cover... and both of the upper camshaft seals are good too... does it mean that i have to replace the timing cover gasket too... or i dont have too...
anyway thanx for price for the part and also the part # too... i check that out later...
here is my past experience about the timing cover gasket... like a years ago.. i use to have a 5mge auto. and i do a 5speed conversion... also i do a 7mgte turbo on the 5mge... anyway... my upper two camshaft seals were leaking oil like sh!t... and my timing cover gasket wasnt leaking at all... but for me to be able to replace the two upper seals i gonna remove the timing plate... aka timing belt cover.. and i remove it and i replace the two seals and also the new timing belt cover gasket too... and then from that moment on... i keep having trouble with the timing belt cover gasket... i keep having oil leak on that plate... and i replace it often...
so i'm not sure if the mk3 will be the same as the mk2 or not... but thats what i have it in the past on my mk2....
