Old 01-13-2007, 03:40 PM   #6
Bill UK
AEM EMS
Bill UK's Avatar
This may be an alternative to welding, they manufacture allsorts of polymers, aluminium epoxy putty etc for repairing worn or damaged castings and shafts; you would need to check out the temperature resistance. Many years ago I repaired an air-bearing surface on a granite bed CNC PCB drilling machine, it set as hard as the granite. I also remember it was quite expensive .Many be worth contacting them for some advice.
http://www.devcon.com
http://www.devcon.com/maintenance.cfm
http://www.devcon.com/devconcatsolution.cfm?catid=16
