Old 12-31-2006, 07:48 AM   #1
j3pz
Originally Posted by Monkey
Apparantly someone wasn't paying attention during the FCD lecture. Fuel Cut Defense is just that. It defends AGAINST the FUEL CUT associated with a turbo car. It allows you to be able to have more fuel at higher boost levels so you don't run a lean conditon. That's what an FCD is used for. Duh.
no the stock ecu will push as much fuel as possible untill it cant push that much. then thats where upgrades such as big injectors, fuel regulator, and pump come into play. however this requires tuning. a fcd DOES modify the signal the ecu recieves, thus running the engine lean...
as stated before: fcd --> ftl
