Old 12-30-2006, 02:55 AM   #1
Monkey
Monkey is on a distinguished road
Originally Posted by ddmcse
why do you need to pull the crank pulley ? you can release the tension and slip the timing belt right off .
Yeah, you CAN do it that way, but if you want to make sure you have everything lined up properly, then you want the crank pulley and lower timing cover off to line up the timing marks, properly. One tooth off may not do any damage, but it will damn sure make it run like ass. Better to be safe than sorry. Believe me. I'm a mechanic. I don't play around when it comes to doing timing belts. I'm not about to buy someone a new engine because i didn't do a timing belt job properly. Funk that.
Monkey is offline   Reply With Quote
