Old 12-30-2006, 12:06 AM   #11
IHateHacks
IHateHacks's Avatar
I've decided to send the head to a machine shop. I've gone this far I might as well go all the way. Cylinder walls still have crosshatch marks on them so it is a safe bet that this engine was rebuilt at some time. I've also determined my BHG was in cylinder 6. Spark plug insulator in cyl 6 was brown. All of the other spark plugs were normal. All of the valves looked the same in cylinders 1-5, cylinder 6 looked totally different. If you look closely at the last picture of the head gasket, look at the last cylinder to the right and look at the top, it is oval shaped. So it is determined that when this engine was rebuilt the HACK that put it back together hacked it up. Either overtorqued or did not torque in the right sequence.
