Old 12-28-2006, 07:05 PM   #1
kwnate
SP58GT
If you go to a mhg you need to have the head and block preped or it won't seal right. This means taking the head and block to a machinest who can smooth it out, most machine shops can't get it smooth enough and you'll need to hand lap it.
For a stock gasket its a good idea to have the head checked and shaved if its not flat, check the block with a machinest straight edge. The stock gasket is much more forgiving when it comes to imperfections. Use ARP bolts or studs and follow the manufactures instructions for torque. Follow the TRSM for torque sequence.
As for the tranny connector, put the car on jack stands. put a floor jack under the trans crossmember and unbolt it. Now lower the tranny until you can reach the connector. You'll have to get under there and bear hug the tranny.
Nate
