Thread: Squeeky Brakes?
Old 12-27-2006, 02:24 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by bpalmer21
...The metal matrix pads would be ok with stock rotors, no?...
"Ok" yes, but do you want braking performance that is only "ok"? If you don't want to use stock pads, then your next step up is Hawk HPS.
...I do really think that drilled rotors would look best, because of my spoke pattern, but not good enough for the cost of the rotors...
Sure they'd look cool, but cross-drilled rotors aren't the best choice for braking power or longevity imo. Cross drilled rotors provide less surface area for braking, so performance is worse. Ime, they also tend to crack and warp more quickly when used with relatively powerful calipers (like the Mkiv Supra's).
Life begins at 30psi.
