Old 12-17-2006, 12:47 PM   #1
84 celicasupra
84 celicasupra is on a distinguished road
you could have a bad fuel pump..when you turn the key on do you hear the pump come on? if not check the relay under the hood,if it is good then most likely the fuel pump is bad,not that bad,i replaced one in mt brother's 84 supra,which had the same symptom you described
84 celicasupra is offline   Reply With Quote
