Old 12-01-2006, 04:35 PM   #25
SilvaT
SilvaT is on a distinguished road
Originally Posted by pwpanas
That doesn't sound right. Are you sure the clutch pedal is adjusted properly?
Yes. That play should not be present IF the clutch was properly installed & adjusted. Who did you take it to?
What "Standard Flywheel" were they referring to? The South Bend Kevlar clutch doesn't come with its own flywheel, and a brand-new oem flywheel should be perfectly flat. If you installed a flywheel that is not flat, then yes, that could also make a difference.
They said they had to adjust it slightly. I took it to a local garage. No i bought the 'RPS Cyn-R-G Segmented Flywheel for 1993-98 Supra TT, the one you suggested, and since this is specifically designed to fit the Supra TT, i don't really see why there should be a problem. The flywheel they were talking about was the orginal "stock" one.
Would you recommend that i change the fork 1st and see how it is, and then perhaps the Slave and Master if need be.
cheers
T
SilvaT is offline   Reply With Quote
