Thread: turbo-charging
Old 11-30-2006, 06:48 PM   #1
kornkid
kornkid is on a distinguished road
the ecu should be able to handle it just the way it is. the uprgraded rrfpr (rising rate fuel pressure regulator) should be enough to get it to run right. if you want to get more boost than 9 psi you would want to look into a super air fuel controller (safc) or the possibility of swapping in a 7mgte.
82 Ptype (6mgte project)
kornkid is offline   Reply With Quote
