Thread: no heat
Old 11-29-2006, 10:06 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by octron
...the heater valve is bust on it . . i am just havin trouble findin it .it looks like i have to remove the whole dash to get at it...
Fwiw I agree you'll have to remove most of the dash to get to it.
...i think i can switch it on constantly but i suppose whenever i do find it .. it would be better to replace it rather than havin to remove the dash in the summer to turn it off
Rofl yep. Good luck replacing the valve...
Also fwiw, I've seen several Mkiv Supras' cooling system components fail (water pump, hose splices, etc.), primarily due to improper maintenance. Ime, the jza80's cooling system components (including parts of the heater core) will only stand up well if your coolant is regularly flushed according to the schedule in owner's manual:
http://www.mkiv.com/manual/manualtt/...ule/index.html
Life begins at 30psi.
