Thread: turbo-charging
Old 11-28-2006, 07:15 PM   #1
kornkid
kornkid is on a distinguished road
if you want to turbo a 5m cheap, a 7m manifold bolts right up then you can use the stock ct-26 which is more than big enough for a 5m, run oil lines and coolant lines (kits can be bought from rabid chimp at a decent price) and put a rising rate fuel pressure regulator on. that setup should be good for about 9psi. bigger injectors such as the 295's are recommended along with a bigger fuel pump.
82 Ptype (6mgte project)
kornkid is offline   Reply With Quote
