Thread: turbo-charging
Old 11-25-2006, 11:50 PM   #4
hangsupra
a completly 7mgte turbo, intercooler/pipe, and exhaust will fits the mk2 at no modification... but if you use the mk3 down pipe and exhaust n your car is drop to... then your exhaust will be 2" from the ground n each time you go over a bumpy road then your car will scatch from the bottom of the car...
the 7mgte fuel injecter will fit on your mk2 but you need to re-cut the old mk2 wired and re-connect the mk3 injecter to the stock mk2 wired... and you set to go....
what you see on the mk3 will fit on the mk2...
