Thread: Missing at idle
Old 11-19-2006, 08:23 PM   #1
hangsupra
if i'm you.... i will check on the fuel injecter... where the wired connect to the injecter... cause some old skool car like that might use the pin in the connect on the injecter... so you need to unplug the wired from the injecter and double check the connection...
cause thats what i use to had on my piston one.... especially when you first step on the gas and it goes from certain mph or certain limit and the car start accel. good.... so my friend told me to check n i did check n thats the prolem i found out...
but what about right now.. did you get your blow head gasket fix it yeah... let us know before i telling you more detail alright.
