Old 11-17-2006, 10:50 PM   #1
Bill UK
AEM EMS
Bill UK's Avatar
Originally Posted by papaleach
my cylinder bore is 44mm and my head gasket bore is 46mm. Will the 2 mm difference make a difference on performance???
Sorry bit confused on the dimensions you have given, stock bore is 83mm dia (3.267 inch)yours are 44mm (1.732 inch) even if you stated this as the radius and not the diameter, your dimensions don’t add up. What are you using to measure this ?
